sim card problem
iamax10user
sim card problem
Hi SE forum admins and guys,
In fact, I have a problem.. I am on holidays now, and I've bought a new national sim card of the country that I am into now for vacations, but it's not working on my x10i... when Phone is booted, I'll have a grey screen with " sim network unlock pin" or something like that, with 2 options "dismiss" and "unlock".... I inserted the PIN CODE of my phone but it didn't work either...
so I need ur help plz... and thanks
Tags (1)
Dr_Chris
Champion
Seems that your phone is locked into the network that you are using, so you need to contact them to get the network unlocking code in order to be able to use other networks on your phone.
8 REPLIES 8
Dr_Chris
Champion
Uliwooly
you have two ways to do this, one find the unlock code so you can use any sim card or two debrand your phone
the later could void your warranty, but you can always flash the original firmware back to your phone
Uliwooly
download FlashTool and the firmware that you need from
http://forum.xda-developers.com/showthread.php?t=920746
Install it and you will see  5 folders
                                   Custom
                                   Drivers
                                   Firmwares
                                   Loaders
                                   X10Flasher_lib
take the firmware to the  "Firmwares" folder
click on X10FlashTool (Application)
click on Falsh
Press Ok
it will ask you to connect your phone on Flashmode (turn off your phone, press the back button, then connect the USB) press OK
Click Flash
This is an step by step guide
I WILL NOT BE RESPONSIBLE IF ANYTHING GOES WRONG!!!
OPTION 1 - Install *.ftf files
1. Install Flashtool
2. Copy the *.ftf files that you `ve downloaded earlier to firmwares folder from Flashtool.
3. Click "Flash" button from flashtool and select the *.ftf file firmware and click "OK"
4. Relax and wait a while. When the proccess is completed you will get a popup message (don`t click on that!!!)
5.
PHP Code:
a. Unplug your USB cable from PC
b
. Power off your phone
c
. Press back button and keep your finger on button
d
. Plug USB cable to PC
e
. Check if the green LED appear
f
. On popup message press "OK" button
g
. When "Found at USB/........" appear on flash tool you may release "back button", sit down, relax and wait
6. IF the "Start Flashing" message appear everything`s ok if not...repeat. Sitdown and relax (again )
7. When last message appear unplug/plug USB cable
8. DONNE
Regards,
Ricardo Rendeiro
Uliwooly
this are backup alternatives
Sync your contacts with Google
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
For SMS/MMS
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
if you dont want to lose your call logs
https://market.android.com/details?id=com.yang.android.ansta
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
iamax10user
thanks guys.. I didn't know at 1st that it's my network provider prob.... I just asked them so they gave me my code :smileyhappy:...
Uliwooly
anytime
Dr_Chris
Champion
Nice one! Enjoy the freedom of an unlocked phone!
Seenu
Hai,
Hai, I think your phone is locked phone.So only it is not accepted any sim card. Once you have unlock your Sony Ericsson X10i  phone after you can use any gsm sim cards. This can be done by using codes. If you want unlock code you can get it from Mobileunlocksolutions.com . Here they will ask your mobile details, network, imei, and country then they will send the code via to your mail.
