Solved! Go to Solution.
Official media applications
Sony Walkman app :- http://d-h.st/htw
Sony Album app:- http://d-h.st/L9p
Sony Movies app:- http://d-h.st/mJI
Download and install as normal application.
Yea same here... got the old versions and its not updating through the update center 😕
me too..have the same problem, the media app (walkman, album, etc) don't updated after a new firmware .205
Things could be worse. If you were a UK customer with an unbranded phone you would have no firmware updates and no application updates.
thx sonysp09, but after install the latest Walkman app, then requires the update for Music Unlimited, when i check for the update there isn't on update centre..
and walkman can't login with a music unlimited.... i have download from play store, but nothing, requires the update from Update centre... what is the solution???
