Whether xperia sp has floating touch or not?
pchetan2
It seems like xperia sp has floating touch techonology. Sometimes when I keep my finger nearer to the screen,a small circle appears on the screen right below the finger and when I point the finger on to icons the open as if they were TOUCHED to open. I can also scroll web pages,move between touch screens.
this occurs only certain times but not all the time
Would like to know if floating touch exists for xperia sp and if exists,how to use it regularly
Jasonwsc
It exists as glove mode. To try, turn on glove mode in settings and try to unlock the screen by moving your finger slightly above the screen without touching it. If it is activated, you should see small circles around the area you are hovering on.
18 REPLIES 18
slimshaddy
Hero
Xperia Sp doesn't have floating touch it happens because of the glove mode. Disable it and screen will behave normal.
Jasonwsc
nmisj
Are you still experiencing this problem? I've disabled the glove ode but the irritating 'floating touch' still exists. How to disable? Help!
ramos
i purchased this phone hardly a week ago.........i too experienced this thing,when i was tryin to change the song, i saw blue cirles/spots in the screen just below ma fingers when i touch and that made me fear......then i swiched off the phone and no problems untill now,Is it just because of the glove mode or some other problems.......please reply ASAP !!!!!!!!!!!!!!!!!!!!
pchetan2
I Disabled glove mode ....the problem is gone Slightly_smiling_Face
pchetan2
Better reset the mobile ,or repair your phone via pc companion
ramos312
thanks pchetan2....as i said after disabling the glove mode there is no problem untill now!!!...............overall i'm satisfied with the phone....and thanks for your quick reply..
saurabh88
I think its called hover.... how to disable it
Uliwooly
Go to the settings and turn off glove mode
