i cnt lock my phone by power button
if i press power button volume box come out
Solved! Go to Solution.
Didn't you just posted on another thread?
based on what you posted you have to take your phone to a Sony repair center as its hardware not software related
Do a service test for power button, volume key etc... Install below software...
https://play.google.com/store/apps/details?id=com.sonymobile.androidapp.functiontester&hl=en
I am experiencing the same problem but if I press the power button nothing happens and the fact that I had this phone for just less than a month. It's very frustrating. I can't use now my phone because I can't turn it on... Is there any alternative way to turn on this phone without using the power button?Thanks
