wifi is not working on sony xperia mini pro sk17i
nish58
My wifi was working a couple of hours ago but now it disconnects automatically. I turn it on manually but it doesnt scan any wifi signals. I tried swtiching it off and then on again but its not helping. Also, i reset my router and tried but the problem still persists. Please help.
Sam
Legend
Legend
That is odd; it would be be worth running an update:
1. Before you start you have to download the PC Companion software and install it on your PC.
2. Once installed on your PC, double-click the PC Companion icon on your desktop to start the update. Note! For some models you will be prompted to do a backup prior to the update and then restore.
3. Install and open PC Companion then select Support Zone.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connection steps
What are your thoughts about this forum? Let us know by doing this short survey.
Sam
Legend
Legend
5. Start.
6. Repair Phone
7. Continue
9. Next
11. Select Phone
nish58
Thank you so much Slightly_smiling_Face
Cloudstrife
I have the same problem, i tried to fix it with the PC companion and still have the problem Slightly_frowning_Face
