Xperia Arc S LT18i How to update the software?
CaseyCrazy
Xperia  Arc S LT18i Как обновить программное обеспечение?
GT
11 REPLIES 11
Wello
Phone is keep restarting after turn on the bluetooth
is there's anyway to reopen the phone or do factory reset from outside (as i can't open the phone)
Noting a tried alot of process for safe mode but didn't success.
Thanks in advance for your support
Jonas
Master
Hi @Wello, sorry to hear about this. Slightly_frowning_Face
Could you try and remove the SIM and or SD cards from your device and see if it continues to restart?
As the device has reached it's end of support, it's not possible to reset it using a computer, so the only option is to try and get the device to start up > performing a factory reset. There are no key combinations to trigger a reset on Xperia devices.
Let me know if that helps!
