Hello,
I have been experiencing a reboot issue on my Xperia V since last night's update to 4.3 Android. I have removed an update to Album, since that is the only other change. If I run PC companion repair, will all my apps be deleted? Any advice other than that?? Help, please.
Solved! Go to Solution.
I want an update, why not; 4.3 seems better, but this instability on (my) Xperia V makes it tough to love :). Needles to say, I have never had this problem prior to the update.
I will wait for a fix/new update, the one that says "fixed reboot issue on some devices" or something like that.
You can also downgrade,but it is better to wait for an update.
How to downgrade - just factory reset on the phone?
After a through dealing with this problem, I have to report that the problem has not been solved. Today, they have returned it from the service, claiming all will be allright, but it rebooted again a minute ago, after only half a day without reboot.
So, SONY, please, do something, this update is a promised land riddled with mine fields. Help, give a bug free update, or something.
Guys, just updated my FW to 9.2.A.1.199. With 9.2.A.0.295 I ran into various problems. It would reboot frequently, especially when I was using GPS for navigation (either through Waze or Google Nav). I can confirm now this problem has been resolved with the new fw. I was using Waze while driving to work this morning and no reboot at all for 1 hour.
For those having similar problem, update your FW as soon as you get the chance. I did mine through PC companion.
after 4.3 update still facing same problem, sony is gonna **bleep** big time.. why they dont have ballzz to fix this issue...
i love this mobile. but this issue make gone crazy.....
if anyone knows solution for this issue. plz reply..:smileycry:
Have you tried a software repair via sony update service?
http://www.sonymobile.com/gb/tools/update-service/
