Aerial connection
Exaunt
Aerial connection
I am confused about the aerial. Does this go to the TV, then the ARC to the Bluray/surround sound and no other connections or does the aerial go into the Bluray first and then how do I get the signal to the TV. Only one connection from TV to Bluray seems to simple!!
4 REPLIES 4
Bravia55HX
nothing to be confused about!, just connect your aerial to your tv socket and connect the blu ray player with the HDMI cable to HDMI 1 on your tv (if its free) and your done!
Exaunt
Thanks for that Bravia. I guess I am thinking about the previous system which had a video player and cables everywhere.
I may need to get back to you as we now have to connect to the wireless broadband. I have a dongle connected to the TV. Hopefully it is simple after that
Bravia55HX
Hi again,
WiFi for some is a mixed bag, sometimes it connects straight up and other times its a bit tricky, but put a bit of christmas cheer behind it and may you get lucky!
have a good one!
Exaunt
Thanks a lot for your help Bravia, much appreciated. You too have a good Xmas
