BRAVIA KDL40RD453BU does not always turn on
johorlo
Hello
I have a SONY - BRAVIA KDL40RD453BU 40" LED TV which does not always turn on from standby from either to the TV button or the remote control.
I have to turn it off at the wall socket and then back to be able to actually turn the tv on.
Is this a know issue?
I have read that if there is a drop in voltage it can cause issues - but its getting anoying i have to keep moving furniture to get to the socket.
It is plugged into a proper wall socket with no poer / surge protectors.
I've never had issues with other equipment.
Any help greatly appricated...
I think if it persists it will be going back to the shop.
John
Tags (3)
Hi there
The first couple of things to try is:
  • Ensure that the firmware is up-to date - see HERE
  • Factory reset the TV
If that still fails and as its a new TV, I would contact the retailer you purchased it from to arrange either an exchange or warranty repair
