Cannot get BBC iplayer on Sony Bravia TV (Dec 2018)
RainbowAnne
Can see there are some previous related posts, but these all seem ages ago and solved by it just starting to work again.  If there is really a solution, sorry I missed it.
i player just won't load, it's been like it for at least a month, or possibly two - registered the problem on the iplayer website.
evetything else works - Netflix, Channel 5, TED etc - just get loading screen and to get out of that have to turn off TV.
any help would be much appreciated.
Mick_D
Moderator
Hi @RainbowAnne, welcome to the Community.
Have a look at this post describing a basic routine to follow which has helped with iPlayer connection issues in the past.
Let us know if you get it working.
Mick
RainbowAnne
Hi Mick
thank you so much for taking the trouble.  I had the latest firmware - auto updates, but I did a full factory reset as the post suggested and boom!  It's working again.
halelluja!
