Sony Bravia TV recording finishes too early & misses end of program - please help!!??
Maxidog12
We have had a Sony Bravia TV for a few months now.  Every time I record a program using the timer recording facility, I watch the program back only to find the last few minutes of the program are missing, it just ends, and usually on an important conclusion.  This is really frustrating!
Has anyone else had this problem, and more importantly does anyone know how to resolve this problem please???
Many thanks
etritd
the recording feature is totally dependent on EPG. the recording will stop at the moment that the show (program) is expected to end. so if a part of the show runs after that was scheduled on EPG, that part would missed in your recording.
7 REPLIES 7
etritd
Maxidog12
Thanks for the reply, what is EPG??  The program's are not running over their expected time, so I don't think thus is the case.
Any other ideas anyone ???
etritd
EPG is Electronic Program Guide, the one that appears onscreen when you press the button GUIDE.
And it's not about the duration of the program. It's about the time when it's scheduled to start and finish. Let's say a program is scheduled from 8:15 till 9.15, but instead it starts at 8:25 and it will end at 9:25. The recording will still run at the scheduled time (8:15-9:15). so, you will be missing the last 10 minutes in your recording.
Testcard
I don't have a recording option on my Bravia, so not familiar with the set-up. Isn't there an option to "pad" the recording by adding minutes to the start and stop times, similar to a SKY box?
etritd
regretful, there isn't.
profile.country.da_DK.title
plysgaard
That really sucks!!!!
I know Sony is not in control of the EPG times, but they could at least make it possible to add addiotional time to the epg recordings!
(actually it was possible before they made an update!!!)
Watching Tv on a KDL-40EX721
Keithsony
My recording to external USB drive (set in advance from the TV guide) used to be fine. It now it starts and stops a couple of minutes early so I miss the end of all programmes. How can this be solved please
