Clear cache ?
riw1246
Clear cache ?
Have a KDL32WD756 smart Sony tv.
Have got Netflix login probs when i use the built in app, have been advised to clear the Netflix cache to perhaps sort it out.
On opening ALL apps and selecting Netflix, i cannot see any option for its settings ,it goes to the Netflix Home page,the settings option there gives no Clear Cache .
Is the option hidden maybe in the TV settings ,although i cannot see it ,any tips welcome.
Would a "factory reset "do it, dont want to try it without getting advice first.
LightFoot
Specialist
Hi @riw1246   This is the Android TV community. As you have a Linux TV, you may get more help in the Other TV community. https://community.sony.co.uk/t5/other-tvs/bd-p/tv_en_1
