HDD Error messages
CHRIS1066
HDD Error messages
Hi, i have a KDL-42W654 . How do I remove/cancel the "error messages" from the HDD playback and title page.
I caused this by setting the timer with an overlap on two programs.I have tried "DE-REGISTER" of the HD but it still remains.
It appears to be held on memory within the TV as it`s still there when the drive is unplugged. The timer operation still works correctly, the HDD is a WD My Passport.
It`s not mega important but it would be nice to know how to clear.
Thanks CHRIS1066
HI there
This may sound pretty simplistic, but have you tried turning it off from the powerpoint at the wall for a few minutes?
Edit: Also, what happens when you press the options button on the remote control, at the place where this message is?  Is there anything to "clear" it
CHRIS1066
I have tried unplugging set for 5 - 10mins, still did not clear error messages. On the error window there is no delete button, nether the Options setting has a delete facility.
I would try Factory Reset but that would also lose all the settings that have been made so left well alone.
CHRIS1066
profile.country.da_DK.title
Nielsen
I guess the answer is that you can't without factory reset. This list also annoyed me at first, but as other small issues, I just ignore it now because it's like you say typically idiotic errors anyway.
