Hdmi
leeownerofsony
Hdmi
I have a sony bravia tv. Does everyone know much about the hdmi sockets?. The tv has 3 sockets My Xbox 360 will work in hdmi socket 2 why is this, are the other 2 dedicated to Sony products. Any help would be greatful.
Tags (1)
gofrost
Hdmi is a connection standard so any device with a hdmi connection should work in any of the sockets on the tv, some of the tv options like bravia sync will only work with sony products
gofrost
leeownerofsony
Thank you go gofrost for your answer I thought it might be the case.
This may sound silly, but was led to believe my new TV had 3 x HDMI connections. I can only find the one, which is next to the power cable. Is there another two, if so, where can I find them?
