Hi all
I got a new kdl32 and trying to hook the wii
Using the wii cable red-white-yellow to connect to the Sony TV
I find the white and red connection (audio) but there is no yellow (video) connecter in the sony kdl???
is that right?
do i need a converter (R-W-Y to HDMI ?) or a different wii cable?
appreciate the help
thank you
Solved! Go to Solution.
simply use the scart adaptor that came with the Wii and plug the cable into that.
thanks for answer
unfortunatley i dont have it anymore....I will have to go buy a new one
any other way to connect? is there a wii hdmi cable?
thanks again!
there you go, get it from there and free delivery!
http://www.amazon.co.uk/RCA-SCART-Adapter-Composite-PlayStation/dp/B0035XB4Z4
