how do I restore my Bravia KDL37EX403u factory reset
roglass53
I ma having trouble getting my sony dongle to work and believe this may be a possible solution
profile.country.hr_HR.title
DamacizSi
I will give You info about.
1. MENU[home]-SETINGS-SYSTEM SETINGS-GENERAL SET UP-FACTORY RESET
2. MENU[home]-SETINGS- SYSTEM SETINGS-AUTO START UP
If You ever have to put in pin code, if Bravia ask for after reset so use 9999
How to resolve when the TV cannot communicate with the Internet using wireless connection?
http://www.sony-mea.com/support/faq/403931/productcategory/tvp+lcd+tv
How to connect my BRAVIA® Internet TV with Wireless LAN Ready or Built-in Wireless LAN to a Internet network?
http://www.sony-mea.com/support/faq/403899/productcategory/tvp+lcd+tv/nomodel
Usb wi-fi adapter just UWA-BR100
DamacizSi
DamacizSi
Regards
Damac
:slight_smile:
