How do I Select the correct Bravia HDMI input for the SKY box
Kevkinsky
I have tried to access the 3d settings from the remote control and it will not show on the screen when on the sky 3d channel.
Catmambo
Have you tried pressing the sync menu>TV options> 3D then you  should be able to switch there? I think thats the right sequence from  memory...
thanks
