Stream laptop tv to bravia how ?
nernesak
I just bought my bravia tv (KDL32EX403U). I connect my laptop to bravia through wifi, I can reach all files my videos pictures music, so on my laptop I'm using crystal tv (some channells coming from internet streaming http://crystalreality.com/crystaltv/) I wondering how to make streaming from my small laptop to my bravia throuh wifi ? Or any other options ?
5 REPLIES 5
slowtrain
Hi nernesak.
I can't see that you can do streaming using Crystal TV to your Bravia TV as it looks like it uses it's own media player. Of course you can simply use a VGA lead and audio cables to connect directly to the back of your TV.
http://support.sony-europe.com/tutorials/tvhc/computer2tv/computer2tv.aspx?site=odw_en_GB&m=KDL-32EX...
Cheers.
nernesak
hi again
I just bought the cable and it seems that there are no voice's coming from tv just from laptop any ideas what wrong ?
Catmambo
You need a separate audio cable as well - probably a 3.5mm to 3.5mm audio cable. VGA only carries video.
nernesak
oh, no  :slight_frown:
so which cable do I need now can u show me in picture?
so I connect vga cable land one more to the audio holes ?
Catmambo
