How to stop the start beep on the KDL-32EX711
profile.country.nl_NL.title
CeesTV
How can I switch off the start beep of the bravia TV KDL-32EX711.
There is no option in the sound menu for this irritating sound.
KDL-CX520
I have another model but it may be similar
On the remote press HOME> sound> scroll down to START-UP-SOUND > press OK to switch it between ON /OFF
Please note if you switch off the beep sound it will switch off the SONY logo displayed at start up too.
This is may be help.
Regards,
KDL-CX520
Regards,
CeesTV
Indeed, you have another model.
No START-UP SOUND to switch ON/OFF on the sound page of the KDL-32EX711.
regards,
KDL-CX520
the below link is for your tv online manual
http://support.sony-europe.com/tvhc/imanual/menus.aspx?site=odw_en_GB&m=KDL-32EX711&s=SM20
in that page, it shows something about Lights up or turns off the Sony logo on the front of the TV. you may give it a try to switch it off and see if start sound will stop too.
Regards
