Is there a way to turn off the idle tv standby
Star65
If there is can you tell me how i have a bravia  tv
14 REPLIES 14
i have a sony bravia model number kdl-40z4500 and i went on to home, settings, features, timer,off and it wont switch off i really need help
Hi
According to the manual:
If you switch off the TV and switch it on again, “Sleep Timer” is reset to “Off.”
Shalamar1963
Nothing I've tried works please help
Altin901
For me it worked by using uper button at the same time on/off button then unplugged the power cable all together. It works !!!
It has drive me crazy as I try it all the options which are shown in here.
I guess cut all the power and restart always works.
Rockiiocean
It took a while but here it is.
Select the HOME> select SETTINGS> POWER> ECO> IDLE TV STANDBY > select OFF
Let me know if this worked for you.
Rockii
