kd49x8505b
smb9634
kd49x8505b
I have had this TV for over 12 months and in the last month Netflix has stopped working with various error messages. I have reset the TV several times and Netlfix will probably work once then I get the error messages. Any suggestions?
6 REPLIES 6
Hi there
Unfortunately without listing those error messages it is hard to diagnose your problem.  Most of the time it tends to be your network/internet connection.
Also, can you ensure that you have the latest firmware installed on the TV.
https://www.sony.co.uk/support/en/content/cnt-dwnl/prd-tvhc/bravia-kdlw-firmware-update-v2704/KD-49X...
smb9634
Error message is ui-113 and yes I have the latest firmware.
I have to relog in each time to my Netflix account
Hi there
Is your internet provider BT and do you have the BT HomeHub3 router by any chance?
smb9634
Yes it is.
smb9634
It would seem that was the case, there are a lot of other people with the same issues. Time to talk to BT.
