KD49x8505bbu:
I have created a favorites list from the Digital channels but they are all in the wrong order. I need to have BBC3 and BBC3 HD together.
I can see no way of sorting in Favorites. Is this possible?
I can see an option to Sort the Channels list but that is long winded and is reset with a Scan.
Can anyone please help?
Solved! Go to Solution.
Hi Q
I can export the stb.xml file to USB stick, i can the edit it
with the sony edit software no problem, but it will not import
it back to the tv.
I have tried a factory restore no problem but it will not import to the
tv it finds the file when i plug the USB stick in asks if i want to install
the new chanel list,when i say yes it says failed.
So now i have tried every which way on this i give up.
This tv will not do this, and yes i can play misic video
from same USB stick.
Try to do the procedură after a full manual scan
Do not select any cable provider from available list
.la
Choose " other" and performanțe full scan, export channel list, sort ghem and import.
For me was the only way .....
For my KDL-32W705C this was the only solution.
Looks like if I choose a provider, and the file, the DVB-C list is bad and can't be imported.
If you don't choose a provide you can edit that list, and you can import it.
