KDL-40EX402 - skipped programs
profile.country.ro_RO.title
tunoi39
Hello guys,
i'm owner of a KDL-40EX402 and starting today i have a problem: after a full search some channel are skipped. For exemple if i push Home and start navigate in the channel list i will see that channel 30 is not on the list but i i enter manually that number then i see what program is momorize on that..
I tried almost every thing i know: factory settings, start full search without any contry ...
The TV has the last firmware on it M8.728
Any ideea?
The skipped thing is not set by anyone...
Hi there
Im probably being a bit thick here, but I dont understand the two points above? Any chance of clarification?
tunoi39
So i try to rephrase that : P
After a full search with country selected (Romania) i noticed something. I dont recieve some channels. So then i started looking on what is wrong... after some time i noticed that in my channel list(button "Home") i have some number missing ... i have the number 29 and 31 but no 30... if i enter mannually this channel then i see what is there... Same thing in EPG i dont have 30 on the list at all... So then i started to look up maybe is some skipped option activate. I didnt find any...
So I used factory reset no result...
The tv have the last firmware...
Hope i've been more explicit now...
tunoi39
maybe a more explicit version of my problem is here:
https://www.sony.ro/discussions/message/1030476#1030476
Message was edited by: tunoi39
