- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi, Will the latest firmware upgrade shown on the Sony web site for the KDL-40HX803 include all previous firmware updates if you have missed any, there does not seem to be a history of firmware that you can reference against.
My TV has version PKG4.085EUT-0108 and the current update is firmware to PKG4.102EUT-0108, it says this improves the usability of TV for 3D sources, as i will not be using the 3D function on this set do i need this update?, if the latest version includes previous firmware updates then i presume i should download it?.
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes, as far as Im aware, each frimware update contains all previous updates. In fact I think the file is actually the whole firmware as opposed to just an updated bit, so rather than just updating the firmware, it's replacing it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
New to this forum and just bought a kdl40hx803. How does one do an upgrade ? The Sony manual is virtually useless !
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi loscotos...... Go to the sony site, download the update to pc or laptop, put it on a usb key and follow the instructions from the sony site to install.......
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks bryfly, will do so.
Regards
Loscotos.
