Almost all my photos when streaming to TV, are rotated 90'.
Is there anywhere I can disable Auto rotation, can not find it anywhere.
Thanks.
Hi there
Unfortunately I dont think there are any settings you can adjust to set it as default. When viewing a photo, press the options button on the remote control and see if there are any options.
You might want to check the settings of your DLNA Server software or whatever you are using to stream the photos as well.
Thanks, but there is no where I can disable the auto rotate.
