KDL-47W805 Danish .srt subtitles.
Hi
Just got my  Sony KDL-47W805 but i cant find out to show the danish letters Æ Ø and Å.
When i run UTF-8 i get an ? insted of æøå. in UTF-16 i get a line with ?????
Non of the iso-8859-x dont work either.
/NETrom
4 REPLIES 4
KDL-47W807
Gem .srt filen i Notesblok med kodningen "Unicode", så virker æøå i underteksterne igen.
Det prøver jeg, tak. :thumbsup:
profile.country.FI.title
Mahti69
Thank you, you've solved the whole subtitle problem!
So the subtitle file (both sub & srt) must be saved as Unicode.
I tried that and it's working perfectly, tack!
KDL-47W807
You're welcome 🙂
