Hello!
I want to buy Sony Tablet S that has Throw fuction. I would like to know if my 2011 year Sony Bravia KDL EX 710 will support this great function. I know that 720 model can support it but will 710 do the same?
Thank you a lot for answer!
Best regards,
Kaspars
Message was edited by: caspers_mx
Solved! Go to Solution.
Hi
Just checked with my colleagues and apparently you can throw to any of this years Blu-ray products, so BDP-S390 upwards and all the Home Theatre kits. Good news!
Hope this helps
Hi
I don't think it can as I think it required a browser on the device to handle this. From memory, the 710 was a 2nd half 2010 model rather than a 2011 1st half model. You may be able to add this function via a connected Blu-ray player though? Maybe have a chat with your local Sony centre or other good retailer who might be able to demonstrate in store?
Hope this helps
Thank you for answer. I also think that this function will not be able. Unfortinatly Latvian local store couldn`t help me at all.
I've also thought about buying some Blu-ray but do not know if this will work there too. I know that there is also some Sony Media Player or Sony Streem Player but couldn`t find any good information.
It now seems that SONY have a lot of great features but no one could tell will they be working.
Maybe someone could help with solution what product should I buy to use Sony Throw from Tablet S?
Thanks a lot - S390 was I was looking for!
