Can you use keyboard with kdl-37ex500. It is too slow to use the remote:smileysad:
Kind regards 1troch
the remote keyboard lite works very well on my samsung laptop so yeah should be just fine. just download it and install on your pc, open it and register your device to it.
Hi
I think you misunderstood me. I were thinkin' if I could use a normal usb-keyboard with my
TV? However thanks for the answer:smileyhappy:
Best regards
Kim
