KLD-40EX403 What is slot for behind plastic cover?
smitht3
Hi all,
What is the motherboard type slot for behind the protective door?
Its not the CAM or CI slot so what is it?
Catmambo
I think its a diagnosis socket or something for engineers.
KDL-CX520
Hello smitht3,
welcome to forum
it is PCMCIA Card Slot, same as the one used with laptop
Regards,
smitht3
Is it though?
There is a slot on the side the same as the old PCMICA (spelling?) slots for laptops but on the back there is a plastic door and behind it a motherboard type of connection (above the standard connections and next to the product label).
Catmambo
