Bravia KDL-46EX503 missing BBC iPlayer, Five OD, LoveFilm and more
mchatter
My Bravia has lost the BBC iPlayer, Five OD LoveFilm and other services whilst gaining new items like Wired and Epicurious. Picasa has also gone AWOL.  The software version is PKG4.105EUL-108.  Can anyone help... Please?!?
14 REPLIES 14
KDL-CX520
Looks like you update the firmware recently
There are two steps recommended after the updating
1- reset your TV to factory default
2- update internet content from menu
did you change your region in the TV start up setting?
mchatter
Thanks for the reply  I've tried refeshing the internet content from the menu with no luck.  I haven't changed the region and cannot find where to access it in the menu to check what it is currently set to! Could you let me know how to do this before I try the final option of reseting to factory defaults...  Thanks
Catmambo
Couple of assumptions
Assuming you are in the Uk right.
You have the latest firmware.
You haven't got any wierd and wonderful proxies running on your router or similar.
Instructions on a factory reset are in the FAQ on the main page - factory reset isn't as bad as it sounds, it just takes the settings back to the out of the box settings so it will force it to re-establish the IP connection and hopefully this time pickup the correct one.
I'd power cycle your device as well, by leaving it unplugged for 10 minutes or so.
thanks
footballmadmax
Ive got exactly the same problem with mineand its the same model could it be anything to do with the digital switchover
When i go into the internet manual all  i get is a synbol to go to internet videos whereas before there was a list  to scroll down
Im not quiete sure whats gone wrong isdoing a factory reset the only way to resolve the problem
mchatter
I haven't lost all of the video services, just the ones listed in the title (and maybe some more that I didn't notice!)  I'm going to try a factory reset and will post the results...
footballmadmax
How do youreset the tv to the factory default settingsand was yours a success
mchatter
I've done a factory reset and when I try to Refresh Internet Content it fails with the following message:-  Configuration failed while acquiring internet content  0  Please try again later  Yikes!
KDL-CX520
Hmmm, are your internet connection fine?
Try delete the network setting and setup a new network connection thru the menu
Keep in touch
footballmadmax
I get a message to call sony with (5006)which is probaly the error code when i do a refresh the connection its quiete confusing why there is no content anymore
