Manual/Remote for KD-28DL11U
i.m.king
Hi There I am trying to locate a downloadable user manual for this tv. As well as it being useful to have, it will also list the correct model of remote control for this tv. Can anyone help? Does anyone have this tv and can tell me the model number from the front of the remote? Thanks IK
Hi there
The remote you are looking for is RM-ED002
http://www.4ourhouse.co.uk/cgi-bin/product.pl?PID=1120233&brand=&model=KD-28DL11U&part=
or the classic version
http://www.4ourhouse.co.uk/cgi-bin/product.pl?PID=1887643&brand=&model=KD-28DL11U&part=
In regards to the manual, you will have to do a Google search (I havent got time at the moment.  Or you could get it here (for a price 😞 😞
http://www.4ourhouse.co.uk/cgi-bin/product.pl?PID=1261461&brand=&model=KD-28DL11U&part=
Hope that helps.
Hi there
Hope that helps.
i.m.king
Thank you Quinnicus.
I have already exhausted the google searches - there are a few spoof sites out there that claim to have the download and then it some other SW they are trying to foist on you (or a virus).  I believe the 28DL11U was a 'special' and therefore not as easy to find.  Closest I got was the KD28dx40 - the manual looked like it was for a similar tv but quoted a RM-993 remote - so there was so much doubt.
Guess we will have to trust 4ourhouse is correct in quoting the ED-0002.
