On-screen info pops up at layer change on DVD on Sony Bravia KDL-32WD603
Hi all!
We recently bought a Sony Bravia 32 Inch KDL-32WD603 model and we are thrilled apart from one thing. We watch a lot of DVDs and we can't seem to disable the on-screen info that pops up at the top of the screen like a banner whenever we pause a DVD or there is a layer change. It is really annoying us!
It is the black banner and in white it says 'HDMI 1 / ARC' and 'Stereo Dolby Digital 1080p' and the time. It is the same as the one that displays when you change channels on the digital TV set-up.
It is a Sony DVD player (DVP-SR760H) too, but didn't do this on our old television.
Any advice on how to turn this off would be very welcome.
Thanks in advance,
Sarah :slight_smile:
Hi there
On an Android based TV you can disable the info banner perminantly.  Unfortunately your TV is not Android based.  I have had a look in the manuals for both your TV and DVD player and I cannot find any settings that will disable this.  Unfortuately it looks like you need to get use to.
