What's the security code I need to enter into the entry form?
Solved! Go to Solution.
The Security Code, is simply what is displayed in the window. Just type it in (its a way of proving that you are a human being)
For example:
I have circuled the secuirty code in RED, so for this instance, I would type in 97coz3
Code will be different and randomised.
Too bad I need to buy a TV to enter 😞
Hope this helps.
Dumb Question coming : What PS4 Competition??
Edit : I found it !
For example:
Hope this helps.
I had adblock on which blocked half the page. Switching it off allowed me to continue.
Thanks for the input.
Didn't win btw:smileycry:
