Removing old DLNA servers.
tallkeith
I am running a serviio media server on my PC on my home network. It streams video to my Bravia Internet TV. When I select video, I see iplayer, demand five, sky news etc, plus Serviio (home-pc) four times. I only need to see it once! I have a feeling it will spawn more instances of Serviio (home-pc) over time as Ive only had the set one week so far.
Any ideas??
Message was edited by: Catmambo - Edited title to help others find it in future..
Catmambo
Yep, you can get the BRAVIA to list all the servers and then simply remove ones you don't want.
Home>Settings>Network>Server display settings.
geriatrix1
Had the same problem, Serviio showing a couple of times and also a couple of other media servers I'd tried out. Surely there should have been a remove option in the device options... Failing any way of removing them I opted to return to factory defaults, which solved the problem, but with the associated hassle.
If there's a better way, could someone please post it. Thanks.
Catmambo
geriatrix1
Thanks so much, very helpful.
