Replacement screws for original table stand (KDL-49WE665)
MartinB737
I need replacement screws for the original tabletop stand (459653331; M MZT) to my Bravia TV (KDL-49WE665).
Any idea on size/type of screw so I can source replacements from my local hardware store??
Thanks in advance for your assistance.
Pascale_F
Moderator
Hi Martin,
Welcome to the Community. You could try contacting Sony Support about this to see what they suggest.
Thanks,
Pascale
Pascale_F
Moderator
Hi Martin,
Thanks,
Pascale
MartinB737
Hi Pascale,
 already did and I've just received M4L12 screws so hopefully they'll fit. Thanks for the suggestion though, the support was indeed helpful.
Regards,
Martin
