Sky 3D on Bravia 46NX713
Rouxdboy
I just bought a Bravia KDL-46NX713 and have read that one needs to manually change to "side by side" 3D formatting. However, when I am on the Sky 3D channel, turn on 3D and press "options"...nothing happens.
Has anyone else had this problem? Any known solutions?!?
Catmambo
Have you tried pressing the sync menu>TV options> 3D then you should be able to switch there? I think thats the right sequence from memory...
thanks
Catmambo
thanks
profile.country.fr_FR.title
6galou
Hi,I have a menu "in french", in the options I put my 3D ok and menu "format 3D"  that is gray .. so no choice!
I do not watch "SKY" but either USB, Disk, or Media-center ..
Thanks,
