Sky codes
funemsifm
Sky codes
Help!I need a sky remote code for my Bravia KDL32WD756 model tv
8 REPLIES 8
Peter_S.
Genius
funemsifm
Sorry the codes did not work
Get Outlook for iOS
Joe_Dohn
Specialist
Why not try the other way around? The TV can control other devices using the Bravia Sync function. Check the manual (page 25).
funemsifm
Sorry I don’t see how this relates to sky codes
Win_88
Specialist
you don't need a code if you have a HDMI connection. You can use (Control for HDMI, AKA Bravia Sync) to control the Sky box with the TV remote
funemsifm
Sorry, I don’t want to control my sky box.I just want to to get sky on my tv with the sky remote.
Win_88
Specialist
It's the same thing you'd do if you want to control the TV with the Sky remote: Use Control for HDMI on the box.
If this doesn't answer the question, I'm not sure I understand what you want to do exactly. If you don't care about anything but getting Sky on the TV, select the correct input and it should automatically start on it when it comes out of Standby.
funemsifm
  1. I think I have misled you,the tv I am trying to control is a second tv run from my digibox through an io link.I just need to control sky on this second tv but there is no available code.
