sony 40ex503 brightness fluctuation
parusht60
when atching the dark knight on bluray last night i noticed on a scene ,were batman was high above a city with the blue sky in the back ground ,the blue of the sky was going slightly ligher and darker as the scenen progressed.this also happened on a scenen of kong kong bay with the sea doing the same .
Bravia55HX
the Ambient sensor could be interfering with your viewing experience set this to off, generally i turn off all picture processing and only add what is needed if any.
so as a good rule turn off all picture processing first and see if it improves.
Bravia55HX
parusht60
hi, this is already turned off as is auto black corrector  and auto contrast adjuster
Message was edited by: parusht60
