UWA-BR100 Internet Connection
noisysandersons
Trying to connect KDL-40CX520 & BPD-S380 to internet via UWA-BR100, but signal strength drop to 0 instantly it connects. Why?
Bravia55HX
or even a faulty dongle!
KDL-CX520
Some factor affecting this such like ,
Distance between router and UWA-BR100
Electromagnetic interferance
A neighbour wireless using the same broadcast channel freq.
enviromental conditions such as exsist of walls , metal etc
The quality of your router
Direction of router antenna (if it is external one)
Many others
Bravia55HX
noisysandersons
thanks for tip, sorted now, very easy to connect once I swapped the dongle.
