Vertical lines on Bravia KDL55X4500
SPMSPM
My TV has suddenly developed flickering green lines when viewing an input signal (both hdmi and aerial signal). Is there anything that can be done? The TV is a few years old so I fear any repair costs are not really going to be worth it. Many thanks in advance.
4 REPLIES 4
SPMSPM
Just to confirm I have checked ll the cables and reset all settings.
SPMSPM
I have just found a / the solution on another forum. for each input mode that is effected, simply change the picture mode via settings. For my tv it is the custom mode that does not contain the lines, all others do.
I do not know how long this will last so I would be very grateful to hear of any more permanent or all encompassing solutions. I hope that this is useful!
cass_n
Community Team
Glad to hear you found a solution @SPMSPM
I think a more permanent solution would be to get it repaired.  You can find out more about this by contacting the Support team here.
Cheers,
Cass
tgoggin
Go to picture settings
Click picture
Scroll to bottom
Set Dcr mode to off
Exit
