W6 Series Motion Flow
scchalm74
Hi - Does anyone know if the W6 Series TVs are 100hz or 200 hz TVs?
Also it seems that there is not a motionflow speed setting, like high, medium, low. From what I can see they seem to be linked to the scenes.
Is anyone able to advise if this is true and if so is sport technicaly the fastest motion flow setting? If so I would use sport and then tweak the other settings like contrast etc and use for all viewing.
This TV is an upgrade from a 50hz so I would like to be able to use the settings if they are available. If anyone can advise that wolud be great. Cheers
Hi there
The W6 range uses what Sony calls "Motionflow XR 200hz.  This is actually a 100hz TV, that does extra processing to "feel like" 200hz.
Hope that helps
Hi there
Hope that helps
scchalm74
Cheers pal that makes sense. It's a bit cheeky of Sony but I'm not too bothered as IMO much above 100 gives you more issues. Motion is definitely better than my old 50hz.
I don't suppose anyone knows if its running at 100 for everything other than game and movie mode or if it varies with each scene is sport the fastest/smoothest setting?
