Wii and Sony
IngolfurB
Wii and Sony
Can you help me hook up a wii on the Sony Bravi?
Bravia55HX
ok, lets see, depending on your bravia model there may be three ways to do this,
one, connect the lead from the Wii straight to the tv using the leads red,white and yellow phono connections the the correct coloured phono jacks on the tv.
two, if the tv has a scart connection, use the appropiate adaptor that came with the Wii, connect the red,white and yellow to the scart adaptor then connect the scart plug to your tv
three, if you set is one of the latest then there will be a special lead supplied with the tv for scart connection, connect this to the rear of the set and simply connect as in two above but to the special lead that has the scart plug on it.
and that should cover it, if it does not auto switch to the Wii, then manually select the appropiate A/V in the menu.
BOBhag
BOBhag
