3D Studio MAX
wegit
3D Studio MAX
Hi Guys
I have installed 3d studio MAX v3.1
When running the software it goes through the procedure but then hangs. The system continues to work okay but the loader for MAX just sits there.
I have tried everything I can think off
Can you help or are SONY now stopping you from running anything other than their software??? :angry:
kee-lo_
No, sony are not stopping you using 3D Max.
Maybe you should check out discreet's website.
