5.1 suround sound -re.pcv-rs346
somerfordbhouy
Bit dim on computers!
have got the above and am trying and failing to connect up so sound system works from all speakers. Can anyone help/advise me :cry:
6 REPLIES 6
Thalamus.
Champion
Hi somerford bhouy,
Welcome to the forum.
I don't think the pcv-rs346 has a 5.1 sound card
kee-lo_
An Audigy 2 would probably be a best deal as it's not too expensive yet does 5.1
chris_lewis
Have you got a 5.1 soundcard? the one supplied isnt capable of 5.1
somerfordbhouy
Many thanks for reply, is this card just a slot in at the back?.
Have tried Sony for solution but not getting much joy at the moment.
chris_lewis
An internal PCI sound card is what you need.
This will do the trick lovley, 7.1 baby yeah!
C
kee-lo_
Yeah that's a sweet card Chris
Yes, it's a PCI slot - or you can get a USB card (not as good IMHO)
