86 degrees after long time cpu usage
fotiselianos
Hi there
After compiling many linux packages on the raw for example compiling a new gcc compiler and generally when cpu usage is at its max for a long time bigger than 30minutes the cpu temperature reaches above 80 with 87 maximum. Are those high temperatures normal?
My laptop is Sony Vaio A series (centrino)
Thanx
9 REPLIES 9
profile.country.de_DE.title
seb21__
I don't know what is whit Centrinos.
But a Pentium4 with over 90 degrees was die.
Normally I would say you have a big problem with your Notebook.
But I think your problem is Linux (hardware is incompatible with the software)
I have the same problem with Linux, but my PCG-FR315s isn't so hot.
The temperature from your Notebook isn't normal.
robpaxton
The Maximum recommended case temperature of a Pentium M processor is 100C. The processor is running within its specifications.
seb21__
100C ........wow:smileyshocked:
kee-lo_
Personally I wouldn't let it get that high, the excess heat will cause long term damage and cause your other hardware to get rather hot too.
Jay1
Yes i agree as well, the cooller the better plus it should use less power if cooller
robpaxton
But, as I said earlier, The recommended maximum temperature is 100C - it's the same as a lot of the mobile Celeron processors. The catastrophic shutdown temperature for the Pentium M is a rather amazing 125C (or 135c - I can't remember exactly). So the computer is running well within the specifications from Intel.
kee-lo_
The term "It's like an oven in here" springs to mind LOL
robpaxton
Intel are normally fairly conservative with their specifications - they rarely push their processors to the limit so I would say that 87C won't cause any real problems.
Most of the time the processor will run much cooler anyway.
kee-lo_
Yeah they usually are.
The lower the tempreture the better performance you get.
