A115Z brightness keys do not work
janvdr
I recently had some spyware on my notebook, but after cleaning all of it (and probably cleaned too much), it seems that my shortcut-keys (the ones next to the power button) do not work anymore.
Brightness: shortcut keys and keyboard keys do nothing, brightness stays at the maximum
Voluwe: shortcut keys do not work, only volume control (software) works
Can anybody help me please?
Thx
janvdr
Problem solved!
(Reinstall the default program 'Utils')
parekhd
Could you expand on how you solved this problem>
TW
Yes, that way also other members can learn from it.
