I belived that Adob Photoshop Elements was going to be pre-installed on my new Vaio TZ21VN but I cannot find it!
Any ideas?
Hi Peter and welcome to Club Vaio.
All the specifications I can see say that 'Adobe® Photoshop® Elements 5.0' is included with the VGN-TZ21VN- including the products page on this site here: -
http://vaio.sony.co.uk/view/ShowProduct.action?product=VGN-TZ11VN%2FX&site=voe_en_GB_cons&category=V...
Try typing Photoshop into the 'Start -> Search' field - you will have to install it and register it for Vista.
If you can't find it, phone Sony Support and ask them to send it to you: -
Sony Vaio-Link Support
Hi Peter,
If you find Adobe Photoshop Elements is not installed on your vaio then try to install Adobe Photoshop Elements via the Vaio recovery utility.?
Thank you! Elements now installed using the Recovery tool.
Peter R Hawkes
You're welcome, it's strange that Adobe Photoshop Elements wasn't installed originally though..
It is odd! I had to install the TPM application as well; since then I have poured a cup of tea on the keyboard with no detrimental effect apart from heart failure so I must not complain!
