Arrow keys not working after USB stick insertion ??? [VGN-Z31WN]
michelemasiero
Is there anyone out there having troubles like me after inserting an USB stick into the ports of the laptop ???
I report the arrow keys not working anymore after insertion (no matter which USB door...).
The keys do not work even if I boot up with the USB stick already in place...
The keys used with any other special key (Fn, Ctrl, etc) do work anyway...
BTW: the VAIO is being used with the docking station (OEM one...).
Only solution seems being removing the USB stick and power-cycling the VAIO...
:slight_frown: :slight_frown: :slight_frown:
Ciao
Michele
michelemasiero
I've come across a temporary solution:
if I press the WINDOWS key, I can still use the moving of the curso around the screen...
Not really a solution but at least a temporary workaround...
BTW: the problem does come out even if I put the USB stick on the docking station USB ports... :slight_frown: :slight_frown: :slight_frown:
Any hint ?
Ciao
Michele
