Hi guys,
Just recently ive noticed some of the keys on my keyboard have stopped responding/becoming less responsive.
I was wondering if anybody can give me any advice on what to do about this. I want to take off some of my keys to clean underneath them hopefully sorting this problem but i dont know how/if i can take the keys out.
Also if cleaning doesnt help does anybody know how/where i can get my keyboard repaired. My laptops almost certainly out of warranty so sony probably will charge alot for such a repair.
Can anyone help?
Thanks, Ali
Hi Ali,
Before going down the route of removing keys which can be difficult to replace, I suggest that you get a can of compressed air and give the keyboard a good blast. This will have no effect if the problem is caused by liquid spillage but will clear out dust and general debris.
il give it a try but i know for sure its not because of liquid spillage that im having a problem.
yep mines about 18 months too. Havent tried compressed air yet the key sort of seems to be working again, it just doesnt respond quite as well as it did. If it comes to it how would i go about replacing my keyboard?
Thx Ali
If we knew your Vaio model someone may be able to offer advice:smileywink:
