I have purchuased a Sony Vaio vpceb1z1e and I upgraded it to Windows 8.1, but graphic card is not working properly. A windows update embeds the specific driver, but it plays any video with no video, but only sound. When I install thw windows 7 driver, conflicts with the HDMI output. At ATI's website shows me to contact my manufacturer. Where I can find the driver for my graphic card for Windows 8.1???
Solved! Go to Solution.
Hi doumasn, Sony do support windows 8 or your vaio and as you have discovered the Radeon drivers on the ATI site will not install on your Vaio.
You could check out mobility modder at HardwareHeaven.com but these modded drivers are obviously not supported by Sony so could possibly have adverse affects or you could check the specifications of other vaio model running windows 8 to see if they have a similar driver.
